Regarding denon 3312 airplay connection and ethernet connection
sachin.shiva
Hi, I am having denon 3312, how to connect it to apple ipod or iPhone. Any having idea. Is it possible to play songs from pc, online radios and through ipod, if yes please guide me
Hi, I am having denon 3312, how to connect it to apple ipod or iPhone. Any one having idea. Is it possible to play songs from pc, online radios and through ipod, if yes please guide me also is it possible to to stream online songs from apple ipod to receiver by giving wired internet connection? I mean can we stream songs from ipod or iphone to denon 3312 ? please ,clarify
__________________
__________________
Looking at the Specs, Denon 3312 does support Airplay and Network connectivity. So yes, when connected to your home network, it should be able to play internet radio, show images and play Audio files. If you have an apple device with Airplay support, you can stream music to the receiver.
Enhanced Network Capability and iPod Connectivity
When connected to a network, the AVR-3312CI lets you listen to Internet radio, play audio files, and display images via an Ethernet connection. The receiver also supports AirPlay, which allows you to stream music wirelessly from an iPhone, iPad, iPod touch, or iTunes. Or, connect an iPhone/iPod/iPad directly to the receiver with a USB cable.
With the Denon Remote App installed on your iPad, iPhone, or iPod touch, you can perform basic operations, like turning the AVR-3312CI's power on or off, adjusting the volume, and switching sources.
MaSh
Connected to ethernet. Then updated denon 3312 online. Installed iTunes on pc. Rebooted pc. Now on iTunes it shows airplay symbol. Played favourite song and iTunes clarity is very good.
