Remote for 2006 model ONKYO Receiver (TX-SR574)
edjamesx
All,
I have 2006 model ONKYO AV Receiver (TX-SR574). Receiver is working fine. But the Remote is gone.
Can you let me know where i can buy the remote.
I am looking for cheaper rates as i don't know how long my receiver will work.
IF any universal remote can work with this A/V receiver also should be good.
Any remote works with VOL +,- at least should be suffice for now.
Why not download an app on your phone (assuming it has an IR receiver) and it should be able to control all the functions. In the meantime I would suggest cleaning the remote. Most times it fixed it. Open the remote carefully, clean the board and re fit it back. Chances are it will work.
You can try cleaning it and using a graphite pencil on contacts where buttons are placed. Worked for me. Refer to this video:
