Recently i got the AVR Denon 1611 & there is one of the option in it called as remote preset code. On setting it up we can manage the BD Player/TV/STB from the denon's remote itself. As per instuctions to setup, it first displays the code of all the devices as per the manufacturer's name which we have to note e.g 30742 & then says to press the source button for which you want to setup the remote e.g BD Player/TV/STB, & then press the device on & power on buttons both at the same time for 3 secs which will also flash the remote light twice & then enter the code.
I tried it but nothing seems to be working. The remote light flashes twice but nothing is being asked in the display. Has anyone able to setup & used it. If yes can somebody please upload a tutorial video of it as it would be quite helpful.
