S 426 by JAMO Floor standing Speaker 5.1
sameerlemos
mumbai
Dear All ,
I bought S 426 by JAMO Floor standing Speaker 5.1 from Singapore last week can you please advice on the amplifier not really expansive but good . and please advice on sub woofer too not very expansive. My room side is 14 by 15 . love to hear music and movie too.
And where I can buy above items in Mumbai. ??
Please advice.
Appreciate your help.
Shwan Lemos :confused::confused::confused::confused::confused::confused::confused::confused:
Hi, you can go for denon AVR 1312 if budget is a problem or even denon 1612. these are really good receivers and will go well with your speakers. For subwoofer, I suggest wharfedale, polk audio, velodyne. all the best!!
Thanks for the info , just wonder how much it will cost me both can you please let me know the price . I will be really grateful to you sit.
Regards ,
Shawn .
What is your budget? For 20K you can consider denon 1312 and yamaha 371. There is a hot deal thread on denon 1312 and 1612 started by denom.
I got that sir , will go for Yamaha or Demon . now one more question it there is any possibility can buy sub woofer worth 8 to 10 K .
Please advice.
you could buy one ,...but the sub will be worthless.
suggest you explore at least velodyne impact 10 or 12...you wud be better off saving money until you can afford HSU stf 2
