Sattelite for Z906
knownsense
Mumbai, India
Hi All,
I have been a spectator so far. Droping in every now and then with casual curiosity. I am not that of a audiophile a very amateur as far as knowledge goes.
I had a jbl escxite 5.1 which went bad all of a sudden after a decent life of 8 years. Liked it for its clarity and sub woofer depth. Sent it for repairs but nothing worked out the JBL service center refused its spares.
Despite a sound starved 6 months, my priorities didn't allow me to spend much on my hobby..and..got myself a logitech z906, a used one.
But sattellite speakers wen compared with the ones of escxite are just noisy boxes.
I just need an advice as to whether i can use my jbl sattelites with the z906.
I know such mix and match can cost me some very dear rupiyaah. But just want to hear it from you gurus.
Specs:
JBL SPECIFICATIONS:
Audio Section
• Surround Formats: Dolby Digital - DTS - Dolby Pro Logic
• Frequency Response at 1W (+0dB, -3dB): 55Hz - 20 kHz
• Signal-to-Noise Ratio (IHF-A): 80 dB
Satellite Section
• Frequency Response (-6db): 120 Hz-20 kHz
• Sensitivity (2.83V @ 1m): 84 dB
• Nominal Impedance: 4 Ohms
• Recommended Amplifier Power: 25 Watts RMS (in sub)
• Titanium Laminate HF: 12 mm
• Paper Cone Midrange : 75 mm
• Dimensions (H x W x D): 111 x 81 x 92 mm
• Weight: 0.5 kg
• Finish: silvergray
Center Section
• Sensitivity (2.83V @ 1m): 86 dB
• Paper Cone Midrange : dual 75 mm
• Dimensions (H x W x D): 83 x 194 x 95 mm
• Weight: 0.8 kg
Subwoofer Section
• Low Frequency Cut-off: 40 Hz
• High Frequency Cut-off: 160 Hz
• Built-in Power Amplifier (RMS): 25 Watts x 5 + 60 Watts
• Paper Cone Long Throw Driver : 165 mm
• Dimensions (H x W x D): 315 x 300 x 310
• Weight: 7.2 kg
General Section
• Power Requirement: 230V/50-60Hz
• Power Consumption: 80 Watts
Z906 sepcifications:
Total watts (RMS): 500 watts
- Subwoofer: 165 watts (6 ohms, at 52 Hz, at 10% THD)
- Satellites: 335 watts RMS (5 x 67 watts per channel {4 ohms at 3.85kHz, at 10% THD})
Maximum SPL: >110 dBC
Frequency response: 35 Hz 20 KHz
Amplifier: Ultra Efficient Class D
Input Impedance: 8,000 ohms, min
Signal to Noise ratio, A-weighted: >95dB
Drivers:
- Satellites: 3 polished aluminum phase plug drivers
- Subwoofer: 8 high-excursion ported driver with 6th-order bass reflex enclosure
Supported digital formats: Dolby Digital and DTS Digital Sound
Source inputs:
- Digital Coaxial
- Digital Optical (2)
- 6-channel direct (3 x 3.5mm)
- Stereo (RCA)
- Analog stereo-mini (3.5mm
Please advice.
