Setting gain on the amp
rajivganth
Here is a video that explains it in detail :)
How to Set Your Amplifier Gain to RMS Power Using Ohm's Law - YouTube
RF level set frequency in wav format. It works pretty well to set the gain for all your speakers and sub.
Rockford Fosgate - RFTECH Support
click on 3Sixty.1 & 3Sixty.2 - software downloads and download the file Track #1, Level Set.
Important notes to use this file.
1. You need multi-meter and set the volume of source to 3/4 of max volume limit
1a. By pass all the DSP functionalities, like eq, fader etc.,
1b. If you have volume level for sub, keep that to 3/4 of max level as well
2. Disconnect all the speaker out from amp
3. For front check left or right with multi-meter for the optimal voltage before clipping
4. For rear check left or right with multi meter for optimal voltage from amp
5. use the formula given in the video to set amp gain
Enjoy the music :) and cruizzzzzzzzzzzzzze...
