Sharing my experience with Micromax Funbook as a wireless media player
Thank you, I purchased the same Micromax funbook. but after couple of months I'm not using it very often. I thought I wasted money buying something I didn't need. Now I have found a use for it. But how does your set up work? I'm assuming you have a windows/linux server running XBMC and you use the XBMC app on funbook to control it?
You need a wifi connection using which you can connect to xbmc.
