small PA System
do you wish to install it?
or want a portable PA?
you need a mixer only?
or mixer+amp?
or mixer+amp+speakers?
Hi aniket ...thanks for ur reply. I need portable one to address 50-60 persons. Plz see the doc.
Dear knairkuttan,
Could you please post a high resolution picture of your requirement. is it required for indoor or outdoor application?
Ahuja is good for PA. the system in the above post could serve well for indoor use but dont expect it to be serious loud outdoors.
Aniket
