smps switching frequency and noise
Sachin,
Om's supply board will not provide enough current for the OP's
application which required 12V, 3A or so.
soundnovice, since Arjen deals with Tripath amps, that supply is likely
to be suitable. T-amps run pretty good with SMPS.
Sachin,
Yes, my PS is only for small current of pre amps and not for power amps.
Also that SMPS will be good option with Class T and class D amplifiers. But that is single rail ps it seems -V looks deceptive. So useful for 2020 & 2024 amps and not for amps which required dual PS.
well....my original doubt is.....
"the description says that the switching freq. is 50khz so noise is not an issue."
i.e. if switching freq. is 50khz, then does it mean that its quality is as good as linear supply? having a switching freq. of 50khz will not cause any noise in the output?
unregulated supplies typically produce a mains induced audible hum at their outputs...a 50kHz smps would push this 'hum' beyond audibility and this is probably being touted by the manufacturer....
but emi noise in a smps is of more concern and emi will increase with the switching frequency...so the designer better have taken measures to suppress the additional garbage.
got the answer! thanks
These are from some older fellows, -
I also prefer SMPS and batteries than heavy transformer.
However, in SMPS, I found that there is always a high ~10mV ripple due to the switch.
The frequency of the voltage ripples is depends on the switching frequency of SMPS.
Normally, the ICs' PSRR (Tripath, LM317, etc.) always performs badly at this frequency range.
So they introduce noise at 10Khz~20Khz range, even the switching frequency is up to 40Khz.
(Because the ripples are not perfect sine waves, and if you do the Fourier transform to the waveform, you will know that it contain lower frequency components)
The higher the switching frequency, the smaller noise in audible range. (of course you can't go too high to the Tripath swithing frequency, that will cause another problem.)
IMHO, you should choose SMPS with higher switching frequency (>80Khz), and beware that many industrial SMPS switching frequency is around 25Khz.
Ref.A reliable 30-0-30 switching regulated PS
For preamps you must go for linear well filtered PS. There is zero tolerance of PS impurity though current requirements are low.
For Power Amps ( specially class-T and class D), it does not matter SMPS or linear. Only purpose here is to get High current, lowest output impedance of PS and ripple is minimal (few Milli volts). Linear PS is bulky and difficult to build high current regulated with higher efficiency (w/o heat loss). SMPS is beneficial on all aspect. You get small ripple which anyway no matter with switching amplifier. So for 20KHz audio, anything >=50KHhz switching frequency (>= 2.5 times) should not matter.
