Hello guys, need little help here!
I bought a new stepdown for my AVR and on the first go i think it blew something inside the AVR, i opened and checked the fuse and other things and they seem to be fine... it is just not turning On. Can you please suggest a reliable repair show in Delhi ncr where i should take it to?
Thanks in advance!
It's no so clear for me to narrow down with suggestion.
Few questions iny mind.
Sorry ,Assuming that you are not DIY guy.
Are you sure the stepdown transformer is working fine?
Any glowing LED or Neon lamp indication is there in your stepdown transformer which shows the input is present inside the stepdown transformer at worst case.?
Possibilities to check the output voltage of the stepdown transformer ?
I know it is not possible for Non DIY guy to check the stepdown transformer input /output.
Atleast you can try with some road side electrician to check the output VOLTAGE of stepdown transformer  before looking for AVR service.
Understood from your request you just connected the
New stepdown transformer and it is not working ,my understanding is correct?
Did your heard any abnormal sound ? Or smell from stepdown transformer or from AVR which makes you to think you blown something inside the AVR?
Stepdown transformer is sturdy and it is built inside metal box.
During transit this transformer position would have moved inside the casing due to bad fixing screws which could create some issue inside the stepdown converter.
I have seen most of the stepdown transformers are physically damaged condition due to the size and packing is not that great for the weight and mainly due to cost.
Did you calculated the power rating for AVR and bought slightly higher power rating ?
Have you ever checked the AVR with some other stepdown transformer before connecting this new stepdown transformer?
Share the photograph of stepdown transformer or model link.
What is your AVR model.?
