sonodyne roarr 210
Hi Friends,
For similar Budget or Less you can consider DIY Route.. You can have 200 watts rms with 12 in driver. I have auditioned some branded in Kolkata including Sonodyne... buy DIY Rocks... You can have both Line level and speaker level inputs because the Plate amp comes with these options.
Of course you need to get the enclosure done by a carpenter. It is much more satisfying when considering the budget.
Ahh..the golden truth. ;)
Class D for a subwoofer is good because Class D is very efficient but has a lot of distortion. But in case of subwoofer distortion is nothing to worry about since it deals with just producing low freqs. So it only makes sense to go class D on subs.
Hi Friends,
For budgets Subs you can consider DIY Route but of course you need to have one carpenter in hand. Considering the budget of 18k or less you can get a 12 inch active sub of 200 watts rms power. The sub amp comes with three controls/ and speaker/ line level input options.
I have auditioned branded subs including Sonodyne...but diy subs rocks anytime than these branded ones..much more satisfying what I can say. If you need some details of this sub then pls PM me.
