sony lcd tv
prerna_rim
india
I am confused between two models of sony klv32v400a and klv32v55o.
i am planning to buy lcd tv this diwali. which one should I buy between these two
spirovious
550 is better for SD viewing, I have seen both side by side.
400 is HDready & 550 full HD.For HD viewing both are same.
If you want for only HD/DVD viewing,400 is cheap & good choice.
GeoTracks
India
price is not so much concern.what is the difference between be3 and be2?morover the difference in money is good around 8000
BE3 upscales SD signals (Tata Sky etc.) much better than BE2. Also, featurewise 550 series is better (USB port [No DivX support though], 4 HDMI inputs etc.). If cost is not a constraint, overall the 32V550 would be a better buy and will be future proof too.
adder
bangalore
well the BE3 primarly improvement is in its upscaling capability.so SD content will be better on the BE3 version.
also why do u want to even go for the older BE2 HD ready V450A series when u can get the BE3 S550A for about the same price.
so u should rather choose b/w S550A and the V550A,the V550A apart from FHD ,it also has a slightly better contrast ratio.
prerna_rim
india
thanks so much. I think my more than half problem is solved. First I was planning to buy klv550a which was of 42900. but yesterday I saw v400a which was of 35590. so this made me in confusion
sunyapu
Go ahead with V550A. Any time better than v400.
