Sony x700 from us/uk
Wharfedale Evo 4.2
efernand1
A player which is clearly mentioned as REGION FREE is supposed to play all supported discs and formats.....
India falls under Region C and UK is Region B....please check.....
EthenHunt
Phoenix(AZ), US / Cochin(KL), IND
Uhd disks will play as there is no region coding for uhd disks. Bluray and dvds will be locked to region B. But most blurays available in India is region free, so should be fine here.
raptor77
I did the same - picked it up from the US - region locked to A for BD. So far, have yet to come across a BD bought in India which is not region free (I watch movies across genres) and didn't play in it. Maybe 1 out of 10000...
Thunderbird8k
India
I bought one from US black Friday deals. It's working fine with voltage convertor. It play UHD from everywhere as they are region free but for bluray it play only region A. Hope it helps
hifitoaster
India
I had a chance to see side by side xbox One s and a under 20k blu ray player, it's the same. Unless you go above 40k, xbox One s is a safe bet. They fixed all the issues with wrong color and atmos. Plus you can play games if you wish. Only Downside is its loud with drive noise and not sure if its a good audio source with that fan.
