Sound Bars sub 30000 INR?
tanmayj
Can somebody suggest a sound bar in the Sub 30000 INR space?
Sent from my Nexus 5 using Tapatalk
Instead of soundbar, simply try the F&D 2.1 speaker set for 5K or so. The new one does FM, Bluetooth and plays USB. Or go for a full fledged Hometheatre for a little bit more cash. Soundbars are aweful lot pricey lifestyle stuff !
Soundbars are meant to enhance the TV experience in terms of the low outputs which nowadays Plasmas & LEDs have.....obviously cannot be compared to even an entry level 5.1 system....
There are powered speakers available in the combination of 2.0 or 2.1s.....check out Swans....
JBL, Harmon Kardon, Samsung and Yamaha have good soundbars...depending on your budget....audition and decide....
Do check on the Philips Fidelio soundbar...it has detachable wireless surround module and will be close to your budget.
In effect it is a soundbar cum true 4.1 surround sound system.
Excellent reviews online aswell
If you prefer sound bar only , then
Add another 10 to 15 k to your budget and get Denon /Yamaha soundbar
