Sound bar for a 165 sqft room
Strings
Hyderabad
Hi all,
I'll be moving to an apartment very soon and I need help in selecting a sound bar for the living room which is about 165 sqft in area.
Needs:
The system will be mostly used for music and OTT movies/series. I'd prefer a system with surround speakers with Atmos capability, but it's not a must. Clarity, instrument separation, deep tight bass is what I'm looking for.
Budget:
Comfortable to spend upto 40k. I can stretch till 55k if the system is really worth it and it won't be an overkill for the room.
Narrowed down options:
JBL Bar 500 pro - 36k
JBL Bar 800 pro - 58k
Samsung Q800F - 38k
LG S95TR - 55k
I'm open to other suggestions as well.
Thanks a lot in advance.
I already own the Pioneer FS52 5.1 setup. I just feel that the towers will be an overkill for the room size and it's difficult to place them in such a small space, so I wanted something sleek that goes with the interior decor as well.
I would happily avoid this investment (on sound bar) but I'm not sure if I can fit my current setup in the new place.
@Strings you can look at sonos arc ultra. They keep running a sale every 3-4 months.
Excellent vocal intelligibility, easy to use and setup, step by step add the sub and surrounds and a minimal wireless setup is ready. Do keep in mind its not comparable to a dedicated HT but for tv series, occasional movies and the room size you mentioned its the perfect fit.
