soundbar for tv
hseplak
I have a Panasonic plasma 50 inch of whose sound i find quite insufficient,sometimes cannot hear clearly even if the volume is way high upto 80%. I don't need anything special for movies but just for watching day-to-day tv.
Will a installation of sound bar help,if yes which make and model should i go for?
just googled to find that Samsung sound bar model f 450 matches greatly with Samsung tvs only!! Any other model to go with Panasonic plasma tv or Samsung is the best option available right now.
Hi ranjeetrain
Can you elaborate on price!!
16-18k.
No, it's not true that it matches with Samsung better than others. There is nothing to match. When you use this soundbar, the sound from the TV is muted. And by itself the sound from this unit is very good.
think so,There is nothing to match. When you use this soundbar, the sound from the TV is muted. And by itself the sound from this unit is very good.
9B7ES5
Chief u can also look in to Boston acoustic tvee 10.Right now is in discount price of 100$ on Amazon .com.
I had purchased same 4 months back at higher price and it's working perfectly with my Sony Bravia.
Where in mumbai can i get boston acoustics?
Chief u can order it from Amazon.com if u buy it locally will cost u more .I had purchased it 4 months back in some approx 13k. Now its cheaper.
Only disadvantages is if u buy from Amazon. Com warranty is not there but I am using it till date no issue.
U can even order the same from Hifi mart on this site right now the discounted price is 19k.
