Speaker stands for satellite speakers
elangoas
Madrasapattinam
Had been to local electronic store looking for mobile charger...
Found these speaker stands in plastic (PVC Material) for Rs 130/- (pair) :ohyeah: Price was too good to ignore it.. So got a pair of stands...
Build is good for the price... Should do good for satellite speakers..
Here are some images of the product...
looks nice.. share final pic after you place your speakers on them ? by the way, i do not see any subwoofer you are using in your set up or I might have missed it?
any reason for it ?
Thanks... Sure...
by the way, i do not see any subwoofer you are using in your set up or I might have missed it? any reason for it ?
Nope...You didn't miss them.. I don't have the sub-woofer... Budget :ohyeah:
Have been using the 5.0 HT Set-up for almost 2 years... Itz been a good/new experience, but the FS are pretty much capable of handling the load...
fET20k
