Rem
what about the Usher BE-718? (yes yes, i am a certified Usher fanboy now)
I would suggest for Dynaudio contour or Proac D28 response speakers. both are amazing in detail and have very good soundstage. having said that, Dynaudio is famous to be very open in nature of sound. therefore, a bad recording will always sound bad in the them. they just do not have coloration (ofcourse this is my opinion and also what experts have to say about them) the excite series from them is not good at all. so my suggestion would be to stay from that model. Now comes to proacs. they are very good company and make some really really nice speakers. one more company you can try is PMC. they make really really good speakers as well.
I hope it helps.
swatantra
Friends
I am looking for suggestion for stereo speakers in range of a lakh to a lahk and half..
This is a feasilbility study for upgrade.
Possible candidates : Dyna contour/excite series, Spendor A5/6, MA Gold GS10, B&W 683(?)...
I would like to avoid speakers that are difficult to drive.
Spidey
What amp and CD player are you using? How large is your room?
Generally, the more expensive the speakers, the more revealing of the quality of the components upstream.
I had been bitten by upgraditis for some time but was worried that the incremental returns I get in terms of sound quality from more expensive speakers may not be worth paying the extra bucks. Boy, was I proved wrong.
About a month back, I moved from Dynaudio Audience 82s to Amphion Prio 620 floorstanders. The speakers are designed by the founder of Gamut and are made in Finland. They are much much more expensive than the Dyns but these speakers are in a different league with truly amazing sound quality. The speakers are a benign load (relatively flat impedance curve and a sensitivity of 90db). I am driving the speakers with the Cayin A88t tube amp (22 W RMS in triode mode) with a Rega Planet CD player. The amp just shines with these speakers. I am now listening to music instead of listening to a music system. These speakers are extremely transparent/detailed across the frequency band and fast with great timing but yet mellow and delicate (including the high frequencies). There is no compression at all at loud volumes and the music just soars without tiring your ears. Just no listener fatigue at all. For want of a better word, they are just delicious and musical. A part of this is due to the low crossover at 1.2khz resluting in the preservation of the midrange frequency signals where most of the critical music (voice particularly) lies. The only downside is that bass in extremely dynamic classical symphonies (10% of my music) does get soft at high volumes. This is due to the low-powered amp which does not have the adequate juice and is not the fault of the speaker. My room is also large (15'x25')
The Amphion Prio 520s could be in your price range but they are floor standers and require a medium sized room atleast.
Some other speakers to consider:
Dynaudio Focus Series: Dyns are a difficult load to drive (I know since I have owned them), but with the right amplifier and CD player they are very good.
Magnepans: Damn good speakers with a beautiful midrange quality but require a high powered amp and harsh with the wrong components. Not sure of their price range though.
PSBs: Good and smooth speakers but some of the floorstanders I have heard (not sure of the model) had a slight mid-bass emphasis resulting in a warmish sound.
Suggest you try the speakers your are finally going for with your components if possible to check for system synergy.
Just my 10 paise.
@spidey. You do have a long list of components to audiotion but i suggest you mention the rest of your chain, your room size, your prefrence in music. sound, your location etc.
It would be more worthwhile for everyone.
All the best
Selah Audio makes some decent stuff too at your price range.
Spendor A6
ATC SCM 11
Music itself is broken up about like this...Hi navin,
what kind of music do u listen to. a lot would depend upon that. .
Please try and audition the Harbeth Compact 7 ES3 .
Just curious why a combination of NAD 748 & Power Amp 955 and not another NAD 777 or 775 ?
You can look at Metas XT 701 in your budget.
If you can pair this with Exposure Amp, Nothing can beat. Try it.
Usually the 50% classic rock doesnt go very well with the other 50% (classical, jazz etc) in terms of speakers.
IIRC the dtqwt is a pretty complicated build
Are you considering rick's kits or speakers?
Heard some people praise the Blumenhofer Fun.
