Speaker suggestions
Rs. 99,900/- as per ProFx site. But I have heard about up to 10% discount. But then their price was Rs. 1,10,000/- not so long ago.
Btw, prices in Europe(particularly UK) and Middle East are typically less than Rs. 90k.
Thanks, noticed HiFiMart are doing the Wireless ones for 179,000 which is a good price, apparently the bass has improved on the new ones but it would mean selling the Amps and DAC which I'm reluctant to do because I'm so happy with the sound they produce.
Until you just clarified,it wasn't clear what you are currently having since Equipment Used could also have been in the past.
Anyway, based on the Klout I assume you like a bit of laid back sound. So Monitor Audio silver series pobably till 200 model, KEF LS50 as others have mentioned, or Dali fazon which is based on the legendary mentor series are some to look at.
If you can source from outside, I know the JM labs Utopia is a dream match with the Klout.
Yes you are correct should have been more clear that I don't currently have speakers as such.
Ya I like sound from the Klout is very adapt it worked very well with Linn Kan mk I speakers - very high PRaT factor. A Linn aficionado told me Klout and Kans are a match made in heaven, with a Linn Majik sub in the mix it was a outstanding setup I had then.
But I am now looking for that laid-back sound as you mentioned. MA Silver are a good choice. I'll research the JM labs Utopia may be a good option as well.
