Also where exactly in Ritchie street is Audio Store. I am sort of familiar with Ritche street which I frequent once in 2-3 monthsAudio store in Mount road ritchie street costin
120/mtr for Bandrige (sorry for spellin mustake )
no not torvin audio store is in first floor
in the main way you turn for torvin
even there is a board kept for audio store
Even Audio store deals with torvin . .
One more question.Considering I use a good quality speaker cable. How long will you think the surround speaker cable can be, before the sound quality takes a hit?
Wires come in different guages (aka AWG). Among other things, the choice of guage also depends on the length of the wire to be used in the application. Thumb rule is the longer the length, lower the guage, thicker the wire. In a typical HT/home audio setup, you use 16 to 12 guage. For most, 16 should be good enough in a typical home scenario (can go as long as 80 ft without any discernible drop in audio quality).
You can find some more info here and here
