Speakers And Amps
reiki
Hi, I am looking out for mu first HOME THEATER SYSTEM nad I need ur Help, Please guide me....
My Room Size is 25 Feet in Legth and 15 Feet in Width, Shall i go in for Tower or Satelite Speakers......... I have seen JAMO S 606 and SPACE 5.1 Speakers.......... Please guide....... My budget is around 50 to 60 K anything less will be appreciated.
Please refrain from posting the same query in multiple sections of the board.
Moderators I suggest that this thread be locked.
Looking for speakers for vx 459
Hello Sir..
I need help from you..
I have a yamaha Vx 459.. and i need speaker for it.. i am confused after refering to various suggestions so long ( just by reading on the site)..
my room is small and i love movie+music both ( ie 50:50).. i love little bass..
i can spend approx 30K ( 10% here and there).
I live in mumbai but travel to Singapore etc. but i guess getting it via custom & flight is problem..
Pls advice me with the possible cost also of Wharfedales 9.x series.
Best Regards.
Re: Looking for speakers for vx 459
Hello Sir..
Best Regards.
If you love bass and have just 30K to spend on a pair of speakers I would suggest you to hear the Diamond 9.5 or 9.6 floorstanders. You can also hear the Wharfedale Opus and Evo series for comparism.
Since you live in Mumbai I would sugget you to cart your receiver to:
Designer Audio India Pvt. Ltd
"Arun Chambers",
Ground Floor, No. 9,
Near AC Market, Tardeo,
Mumbai - 400034.
India.
Tel: 91-22-23520320
TeleFax: 91-22-23512836
Email: [email protected]
for a listen to the Wharfedale speakers.
Hello Sir
I checked EVO.. on net.. it look decent..
what would cost of these evo..
reply soon as i plan to check it by weekend.
Hello Sir
Please contact the address below for the cost of the speakers!
"Arun Chambers",
Mumbai - 400034.
India.
Tel: 91-22-23520320
Hello Sir..
Actually i being there and check the peice ,, it quite neat in sound, however little above range then my amp ( yamaha 459).. however i guess i can still buy it (with futuristic view).. so i wanted to have feed back on the model and expected cost.
best regards
Suggest you to auditon TANNOY FUSION 4 tower speakers, i think it is best
in price tag and you should contect to Mr.Jignesh Katiwala and his mobile
number is 09825133320.
