Speakers and Setup Suggestion for Home Theater in Apartment (3-5Lacs)
mystikmonk
Bengaluru
HI All,
I am a beginner audiophile and slowly building my setup.
I want to configure a HomeTheater for my living room in a 3bhk apartment.
Wanted speaker suggestions for the same .
For AVR , I am thinking of Denon 3800h.
Also as I am inclined to both music and movies (Atmos) . What speaker combination makes more sense ?
Go with maranz cinema 50 ir onkyo Rz50 Klipsch speaker's . And good sub like svs pb 1000pro ir 2000 pro or Ascdndo sv12.
Mine us also in apaftment. Using kkipsxh with marantz 50 and sv 12. Possible go with some minimum accoustic treatment.
First you should start off with listening to various aoeajers and identify your likes.
Also what is the length of the TV wall? Distance to TV? Do you have space for floor standers ke you want to place on TV unit? Have you identified how you will mount the surrounds? What Atmos speakers do you want, in-ceiling or angled? Do you like warm(Wharfdale) or bright(Polk) sound? Do you like extention (ported sub) or tight bass (sealed sub)?
You need to answer these for yourself first.
HI All,
Depending on the size of your living room, the size of the speakers and the sub will differ. What are we working with?
Thank you for the pointers . Will work on the advise
Two main factors - Room size and how loud you can go. If not very loud you may not need large speakers. Can go for HTIB or some new gen HT setup like Sony HT-A9 or the new quad.
