Speakers For Parasound HCA 1200
Guide me some good speaker for Parasound HCA 1200 Amp.My budget is 15 to 20000.
The Parasound 1200 is a very powerful amp, and you must look for speakers that can handle power from some 100 watts to abut 250 watts. Sensitivity should be around 96dB. I am not sure you will get such speakers at 15 odd thousand.
:confused:
I dont know too much about the Parasound 1200, but whats the connection between this power being on the high side and the speaker having to handle power between 100 to 250 W? Moreover why does it need to have such high sensitivity? In fact the speaker can be of lower sensitivity provided it can handle higher power since the amp can put that much power out anyway. I am a bit confused with this reply, what am I missing?
cheers
