Speakers for Yamaha 3067
sskcontrol
CHENNAI
I am planning to buy Yamaha 3067 receiver. Interest will 50-50% for movies-Music.
My Hall size is 20*14 Ft. I am keeping max budget around 50K for 5.1 speakers (for full 5.1).
Kindly help me with the speaker brands with good quality sound filling this room size. Also suggest me the place to buy those brands in chennai.
Speaker can be FS or bookshelf, but quality is expected in this price range.
Thanks for your help and support. :clapping:
Senthil
Senthil
Which dealer is offering 3067. I checked few places and got the reply it is discontinued. Only 2067 is available:sad:
Have you bought anything this expensive from infibeam.
For me it's either amazon, flipkart or eBay or the local shops.
The feedback about infibeam is not so encouraging.
Infibeam is not that bad and you can buy if you want HTR-3067 at a cheap rate..but let me remind again..you don't get warranty!
Better option is check "Yamaha Music Square" OR "Reliance Digital Store" at you locality.
Store Locator: locate a Reliance Digital or digitalxpress store near you
They may have stock and you DO get warranty AFAIK.
I meant the Yamaha rec. not the speakers. sorry about the confusion.
Check with ProFx if it is available in Coimbatore. Last saturday I auditioned this and the guy said they have 3067 in stock. Also, modern world guys in bangalore seems to have stock of this model.
I thank everyone for your valuable comments. Can you please let me know if there are any other AV receivers in the similar price around 25K which also need to fill the sound for 14*20 Ft hall with quality.
Senthil
