Speakers help
bannuparamount
india
Hi guys. I recently purchased denon PMA-510AE amp for stereo setup. I want to know can i a get a decent pair of book shelf speakers under 15 -20 k price bracket. What are the options I have, let me know. Please give your valuable comments which will be highly appreciated.
No body is responding..just viewing the query and passing away..is that silly the question is..come on guys pl respond..i think to suggest it takes 30 seconds..am i not eligible to be helped??
Denon pairs well with polk speakers. Check out the polk tsx220b or the rti a1 which are in your budget. However you could check out jamo s426. One of the fms purchased it for 19.5k. Also check boston acoustics a26. Your choice of amplifier should have been based on your speakers. Have you brought the denon amp already. Would suggest a marantz otherwise.
Thanx for all your responses and i feel relaxed by seeing some of our friends trying to help me out. 1 year back i purchased yamaha rx-v475 and paired with jamo S 426 hcs which are going well with the setup... recently I purchased denon amp and looking for a decent pair of bookshelf speakers for a stereo setup for listening music..based on that i requested your suggestions..Now i have tight budget and not able to stretch more..i will follow the link given in the reply...thank u all
In this situation since you are well versed with all brand's And already own a home theatre. I think since you brought denon the Polk will go well. I'd also recommend you to audition taking your amp to the audition and request the dealer to connect it with your amplifier and then buy what your ear tells you to
Dali Zensor 1 should be on top of your audition list. If you can stretch only a little above 20K then you must hear the Usher S520 too. The Ushers are in a different league compared to what we have in this price range.
