Specific Speakers
Rud31
Haryana
I'm planning my future build and although I haven't set a budget in my mind for it, I do have few technical queries regarding it. I intend to create Digital source based setup as most of my music is either in my hard disk or on my phone or I stream from online platforms. The music I usually listen to is 70s and 80s Rock and Pop, Synthwave and Movie soundtracks. The audio signature that I prefer is one with a wide soundstage, proper separation. It should neither be too bright that it may cause fatigue, nor too warm that it drowns vocals and mid bass. I have seen and read from reviews that Klipsch makes speakers that give such sound but they have poor off axis response. Are there options that fit the bill in under 1 lakh ? As I wrote earlier, budget isn't set but this is just to have a ballpark idea.
Dali Oberon 7 should be ideal...Ive tested the above genres of music with it and it sounds great. If you can spent more (28-29k more) go for an Dali Opticon 6
