SPL Meter
renjith lal
Detroit
Hi All,
I need to integrate two sub woofer to my HT setup. So manual recommends to do level matching using an SPL meter before doing room correction. I am planning to buy an SPL meter to do this. Can any one suggest a place in Bangalore to buy it.
Also can you guys suggest a good model to buy.
I once bought one from SP road and it was okay. This was 6 years ago. But the build quality was poor. Later I got the RadioShack one from Amazon during one of my US trips and I use that RadioShack one now.
I live near Whitefield. If you are also living close by, you can use mine for your setup.
Let me know.
I went to SP Road and searched, found one or two models.
Some unknown brand and it was expensive compared to Radio Shack model and build quality was poor. I didnt buy.
Thanks a lot John for your help. Can you pm me your contact number. I will call you.
I am using two different subs hence level matching is important.
