Stabilizer required for home theatre
I use the v-guard stabilizer which they usually use for ACs. Its working fine till now
What is your home theatre setup consist of?
V Guard has come up with voltage stabilizers meant for home theatres.
The Stabilizer plug for Digi 200 works with 15A plug which cannot be used in the traditional pin socket where as the Crystal Plus is 6A plug. Also if you have your power socket under UPS, it should be removed from the UPS line and should be part of the main line since the voltage stabilizer requires enormous power which a UPS cannot provide.
The cost of them would be 4200/- and 3500/- approx respectively.
Better you buy from showrooms which provide a warranty.
My setup is denon avr 4300h,klipsch speaker package,optoma projector
Sent from my Le X526 using Tapatalk
Good Info.
