Stereo system 30-40k
vishnu
i am a newbie when it comes to speakers and amplifiers,hence i need help(a lot of it!!!)
Planning on buying a stereo setup,have a budget of around 30-40k
As far as speakers are concerned i found good reviews for Dali zensor1 and boston acoustics a26.
how good is norge 2060??will it pair well with the above mentioned speakers.
Also it would be of great help if u could suggest other options.
You can look at the following Stereo amps.
Integrated Amplifier
Cambridge Audio / NAD / Marantz are good stereo amps within budget for some. Rotel, Emotiva etc are expensive ones. Depending on your budget, choose wisely.
There are lot of demo videos over YouTube which can give some level of guidance to help you in your decision. The Key is to audition as many models / brands and make the right choice.
dont miss the wharfedales in that budget. also the bose 301 is a good speaker as well
Hi Vishnu,
If your budget is tight, you can look at the online classified websites like OLX or Quikr or HiFiAds where sellers are selling off good stuff. There is an ad for polk bookshelf tsx 110 unused with 3 years warranty on hifiads
There are also ads on stereo amps
Take a look @ Onkyo TX 8020 stereo receiver with Digital inputs.... Add any BS speaker in the range of 15K, you are good to go.....
