Streaming medium
krismohan
Hyderabad
Hi all,
My friend is trying to setup a compact stereo system for his Kiddo... he has a pair of JBL control one speakers which he wants to hook up and was looking for an inexpensive way to do it.
Needs input on how to get the very best audio possible while streaming over Bluetooth, that lets you not only stream music from your Android (or any portable device that supports Bluetooth 3.0 or higher with A2DP) or computer, but will sound as good as you want it to sound.
TIA
If you mention your budget,you will get more suggestions with offers.
" Inexpensive " meaning differs person to person :) .Hence the silent in this forum
Maybe he can look for 2.1 powered bluetooth speakers. He will have to find a way to ise jbl instead of bundled satellite speakers .
Thanks,
considering he has a power amp to drive the speakers, what is the best way to do it in a budget up to 6K
Will this be compatible to connect with the amplifier via RCA?
Just buy a cheap bluetooth amplifier from Ali Express and you should be good to go. SMSL is a decent company to start with.
