Sub-Woofer Suggestion
Imran
Delhi NCR
Hi!
First of all thanks to everybody for suggestion and help for the AVR and speakers. I got the Marantz SR 5009 with Monitor Audio MR4 speakers.
I do have a little money left over and I was wondering if I should add a sub.
Any suggestion on a decent sub, not overly expensive and something that will go well with my current setup.
The budget is between 20-40.
for 40 k i guess your best bet will be svs pb1000 , if you are on a budget i would suggest the cambridge audio aero 9 sub, velodynes are also gud but impact series is the budget line from velodyne the rms power is least for velodyne(12) 165 rms, svs has 300 watts rms , aero 9 500 watts rms, but the svs is rated to go lower upto 19hz, also if music is your main concern then go for sb1000
