Substitute speakers for Onkyo skw-390
HARVISING
Varanasi
Hi, I own Onkyo HTS-S3400 which comes with skw-390 passive sub woofer (8", 6ohms, 130 w, frequency response 30 Hz to 150 Hz.).Would like know a better,more boomy replacement for the subwoofer,(active/passive).Thanks.
Your AVR has a passive sub output.. Even if you add a bigger passive sub, the power will be limited by the AVR output..
But, if you were to add an active sub to your AVR, then you will need to choose a subwoofer with high level inputs & outputs.. Pic below for example..
images
You will need to set subwoofer as 'NO' in your AVR settings, which will redirect the bass to the front left & right speaker..You can then use the speaker output terminals on AVR to connect to speaker terminals on the subwoofer, and to connect speakers from subwoofer, with a crossover on the subwoofer.. Might be clumsy with wires, but will work until you upgrade your AVR..
What is your budget for subwoofer?..
images
Thanks,that was helpful.
