Subwoofer suggestions
vinothkumar
Chennai
Hi Guys,
Please help me to buy a 10" sub woofer for my SONY STR DN1050.
My budget is 25K to 30K.
I am not interested in Polk, Yamaha and pioneer models because they produce muddy sound. So please suggest me some other good models.
Both for music and movie.
Thanks in advance.
Hi Guys,
Thanks in advance.
I think a Velodyne Impact 10 should come with that budget. Look at the new purchase thread one of the FMs had posted his feedback as well as the price.
Thank you vineetrad.
Anything which has loweset frequency response for low notes? With class D amplification?????
As manniraj recommended, Velodyne Impact 10" will be the best bet in that price range. If you go a bit above you can get an SVS 1000 which is highly rated among the HT enthusiasts.
If you want lower response then SVS, Velodyne are good as already mentioned, Sunfire is also okay. Go for a sealed sub if music is your main focus and ported if you want a mix of movies and music.
Thanks vineetrad and determinus.
My preference is 50% of movies and 50% of music. So please let me know which one is to select. I am ok with 10" driver itself.
Can you guys please tell me which model from both SVS and Velodyne suitable for me?
This will be one time
investment for long, would suggest to go for SVS as mentioned earlier, you won't regret I bet...
Hi Guys,
It seems like SVS PB1000 is not coming under my budget. Can you please suggestion little below from velodye or JBL or something else????????
Hi Guys,
Why don't you try klipsc r-110sw....??
I'm using 2 klipsch r-112sw subs.. they sound great for movies and music..
Thank you badass09.
It seems looking good for me.
What is the quote and where can I get this in Hyderabad? OR somewhere else in india.
Thank you badass09.
Found these authorized dealers on klipsch's website.. i don't know about the prices man but you can try sending the dealers a mail or a call to check on pricing.. i bought my 2 klipsch r-112sw for SGD$1199.00 each..
