suggest 22 inch Monitor for Xbox 360
alokbharti
hyderabad
Please suggest best 22 inch monitor for Xbox 360 console.
It should have HDMI port and audio out from monitor.
In built speakers are preferred.
budget max 12k
can consider 23/24 inch if within budget.
Pour in your suggestions.
Thanks in advance
I do not find HDMI port in this model :(
Get a dvi to hdmi cable(costs 200 bucks on ebay). Then route the audio through analog or optical out (check out if present on xbox 360).
But picture quality is stunning on Samsung LED monitors and far better than dell. Samsung monitors are almost as good as their high end led tv in picture quality.
unfortunately no analog audio in Xbox360 when HDMI port is used.
Optical port is there. but that demands a Home-Theater Setup.
An AVR and 5.1 speakers..will cost a bomb.. Not intended for my requirement..
A simple HDMI capable monitor with analog audio out (after decoding the audio from HDMI input).. This is what I need.
Kittu's suggestions fits perfect.. let me know if there are more such options with other brands.. in 12K budget..
If you can stretch to 14.5 to 15k you can buy LG D2342P which is a 23inch 3D LED Monitor with HDMI v1.4. It offers gr8 2D PQ and the 3D is not bad for the price, they even give 1 3D glass free. You can get it cheapest in Computer shops for around 14.5k if you bargain hard:)
on exploring online and in the shops.. found few more options..
viewsonic
Viewsonic ? VX2453mh-LED
24inch, in built speakers, 2xHDMI
~INR 12.5K
benq E2220HD
22 inch, 2xHDMI, in built speakers
~INR 9.5K
benq G2420
24 inch, 1xHDMI, no speaker but audio out is there
~INR 11.5K
LG 2360V
23 inch, 1xHDMI, no speaker but audio out is there
~INR 11k
I am more inclined towards viewsonic..
the non HDMI version of the same is best seller on amazon.com..
Please share your opinions..
viewsonic
~INR 12.5K
benq E2220HD
~INR 9.5K
benq G2420
~INR 11.5K
LG 2360V
~INR 11k
Don't buy benq 2220hd as it is an old model. dont buy viewsonic as the pq is not overwhelming. lg is pretty good. i dont know about the other benq.
going for viewsonic.. this model has excellent online reviews.. also the build quality is better than LG..
2xHDMI and internal speakers are handy in viewsonic..
LG has good reviews as well.. but there are few complaints..wobbly stand etc..
Aesthetically LG is much better.. very thin panel and crystal like stand.. those are not my priority..
