suggest headphones!
new delhi
hi everyone
i need your help buying headphones.
i have a budget of a 110 dollars (MAXXXXXXXXX, cant spend a rupee more)
i want closed headphones, unless there is very little sound leakage from the headphones you suggest.
i also need the headphones to be very comfortable, as im going to be using them for hours at a time.
my source is going to be wither my samsung galaxy s, or my computer.
ill be buying the headphones from USA, primarily because they are much more expensive in india. if you suggest a pair which are priced at par with usa, i will obviously buy them from here....
if there are any good local brands, i dont mind listening to them either.
i DONT like Too much bass, and i absolutely HATE overtly bright sound.
i NEED my headphones to sound balanced, and to have a very natural trable...
i mainly listen to classic rock and a little bit of jazz and pop from the old days.
thanks a lot, please reply
hi everyone
MDR-NC7 | Black Noise Canceling Headphones | Sony | Sony Store USA
I bought this last year from the US and been using it with my Ipod touch. Since you are saying that you dont like too much bass, this one could be apt for you. I enjoy listening with this every time!!
