Suggest speakers for Onkyo NR616
gnana
I ordered Onkyo 616.
I need to choose speakers for my receiver now.
I usually use it for movies and rarely for games.
my living room size would be 13x25x10.
my budget is around 50k. I have audited Onkyo speakers package itself. I am totally satisfied but they have demoed it with small room setup. i realy dont have clue how it will perform in my living room.
Please sugget me some better options, I also have some plan to buy only a pair of floor standing speakers ,center and sub alone if speaker budget goes above 50k
Mordaunt Short pairs decently well with Onkyo
Mordaunt Short Aviano 1's fronts - 17k
Morduant Short Aviano 5 center - 14k
Morduant Short Carnival 3 surround - 8k
Total - 39k
(Alternatively you can look at the Carnival series fronts and centers and you will save some dough)
you would need to budget an additional 17k-25k for a decent subwoofer to fill you large living room
Example Velodyne Imapct 10, Polk Audio DSW Pro550, Klipsch SW350/450, etc etc etc
Sonodyne Sonus range might fit your budget....Consider them too....
Hi i had been to HT Store 2day to buy speakers for my onkyo 717 amp i liked velodyne 12 impact u2 can buy same woofer along wit tannoy 5.0 package below 50k.
