Suggestion for Car Stereo and Speakers for Grand I10 in chennai
ajay600
chennai
This is my first car and I decided to buy Grandi10 Era. I need to install a head unit and Speakers for my new car. I am not a audiophile and I require the following features USB, AUX and FM.
Max Budget - 4.5k for head unit and 3-4k for speakers.
1. Should I go for 2 speakers or 4 speakers?
2. Please suggest a model for head unit and speakers. How can make sure that they can fit in my car (any specific dimension requirement?)
3. Will I void the warranty if I do the installation outside?
4. How much will the installation cost?
5. Could you suggest a good place to do the installation in Chennai (preferably around Marina Beach)
Go with jbl cs6s components for fronts ( 2700/-) and any oval 6x9 speakers for rear(3000/-) and head unit pioneer (3000/-) which is decent entry level setup in my opinion.
Bass will be good enough from ovals and vocals are from components.
Sent from my Lenovo K50a40 using Tapatalk
I think in chennai, royapettah is the place for good installation. There are lot of shops near ea where u might get competitive pricing. ALWAYS buy the same series speakers from the same brand for front and back to keep the sound uniform.
