Suggestions for HT Systems for 50k and 25k
ashwarsadh
New Delhi
Hello Everyone,
I have 1x Samsung 8 series 55" 4K 3D TV and 2x Samsung Series 6 48" TV. I need to buy HT System for all 3 of them. I am a novice user based in Delhi.
Actually, I had setup internal wiring in 4 corners of my all 3 Living Rooms during construction(generic Copper+Aluminium coil cables)
Now, I want to install HT System of upto 40k - max 50k budget for my main living room it will be used for 75% movies, 25% TV Content. I need to mount these speakers .
I have read alot on this forum, and found that Yamaha YHT299 is really good.
Regarding other 2 living rooms, usage would be low (50% music 50% movies)
I was thinking of going for a soundbar maybe, as I am not sure about my internal wiring, as electrician has left hidden 1 wire inside the wall, So, I need to search for the lost wiring.
If soundbars are really bad compared to 5.1 systems in same price range then I can go for the wiring troubleshoot.
Kindly Suggest me Best HT System for upto 40-50k max
Also suggest me best Soundbar upto 25k or if HT Systems are MUUCH better than soundbars, then best HT System for 25k.
