svs pb2000
annapl
PUDUKKOTTAI
im interested in buying svs pb2000 hows its performance
and what is the price in india
acousticart gave me a quote of Rs.96,000/- :confused:
Strong advice to check other brands first and make an informed decision...
I been using BIC America over the past 2+ years ...changed 2 models and very happy with the performance....
You can refer to the respective brand owners threads we have and also see content under subwoofers
Instead of buying PB2000, you can add one more PL200 and have dual subwoofers.
There is no end to the subwoofer hunt..
svs pb2000 is very good , you will not be disappointed.
its one of the very good subs for the price.
pl 200 is great but i am looking this for my friend
Not looking to takeover the thread but how do you find the BIC sub, what is it being used for? Music or Movies? Are you using the speaker level inputs?
I am not quite in the market for a sub yet but am doing my due diligence, in near future will get one.
Bic is for movies its a couch shaking sub not boomy at all but reg music its acceptable
im using LFE input
Dont intent to start a debate or table tennis here...
I have been using BIC Subs for close to 2 years now....for music it is very good....(80% use) and movies are awesome....i think its all on what settings you are able to make on the AVR to ensure the equal harmonious blend of all required frequencies across all types of speakers connected...this takes time and you need to play with the settings thill you are able to achieve the desired listening satisfaction....p.s. i am not a bass head...i appreciate clean bass across maximum or all low frequencies...
@ shibashis,
There is a dedicated BIC America thread where you can post your queries which will get first hand responses from the BIC owners which can help you to make a proper decision...
