Love4sound
Will this be compatible with the bic pl 200-ii and worth installing
I think the spikes are removable in bic. And what you mean by use some isolation in lieu I don’t understand.Doesn't matter what sub you have. Just see if the spikes on the BIC are removable . If they are removable then the sound path isolation can be used in their lieu, and it should considerably tighten up the bass. Especially on tiled or hard stoned floorings spikes just don't cut it. Use some sort of isolation in lieu, and there will be a certain improvement in the bass.
Wat sub ur using?Been using these on my sub from the start.
Never got to compare what it sounds like without them.
Never tried
Ok it’s very cheap r u sure it will be as good as the svs?Try gym rubber tile.. it provides good isolation.
Didn't try svs .. but tried rubber tile with genelec 7060b subwoofer in 2 rooms . . Gave surprisingly fantastic results in both room..Ok it’s very cheap r u sure it will be as good as the svs?
Ok will give it a try. Can u give me the link for the same product? Don’t know how to search or purchase itDidn't try svs .. but tried rubber tile with genelec 7060b subwoofer in 2 rooms . . Gave surprisingly fantastic results in both room..
This rubber tile has very small air spaces.. rupees 250 per tile.
Bought it from a local shop in Hyderabad.Ok will give it a try. Can u give me the link for the same product? Don’t know how to search or purchase it
Ok what type of shops sells them? Does the product has any brand names ?Bought it from a local shop in Hyderabad.
Ok what type of shops sells them? Nd the product that u got Ny brand names ?
Ok sure@Love4sound please feel free to use proper spellings.
I haven’t checked with any svs dealers. In amazon India it’s sold for 6842. If I decide to get it i will buy from us when any of my friends or relatives visit as it costs only 49 dollars which equals to 3500 inrHow much have they good quoted you for the svs?
Try this. Just 500 rupees.Ok what type of shops sells them? Nd the product that u got Ny brand names ?
Thanks will check it outTry this. Just 500 rupees.
https://www.amazon.in/USI-SUPERTUF-...KoLP9CHdR4ZI_689cHAbcaAh9IEALw_wcB&th=1&psc=1
@sriram_shol Nothing actually. Went through a lot of video reviews in You-tube and it seems like isolating the subwoofer from the floor is the right way to set up the sub. So i just wanted to see if installing this would have any improvements thats all. No harm in doing small experiments right?Just curious, what are you aiming to achieve from installing this?
