himeshlem79
Recently bought a LG C1 and pairing it with an older Yamaha RXV475. Initially I set up all the streaming apps through the TV instead of using the cable box apps. Initially, I had no sound, yet had sound when watching cable tv.
After fumbling around, finally got sound to play when using the streaming apps on the LG tv itself. Now I’m sitting down to watch a movie and having to fumble through sound issues. First the voice track is much lower than the rest of the soundtrack so you can’t hear the spoken parts as well. When I turn up the volume, the receiver shuts off after about 10 minutes. When I use the streaming apps via the cable box, the sound stays on but the voice track is still lower.
I have tried varying HDMI cables, including ones that are supposedly able to play 4K. I don’t know if this is a problem with the receiver itself - is it just too old tech for the new TV? Or is it something else, like the speaker wires? I assume it has something to do with the ARC. Not sure if I should just get a newer receiver. I’d do ghat if I knew that was the problem. Everything seemed to work with my last Tv.
Is there something else I’m missing? I should add, when I watch regular cable TV so far it appears the sound is fine.
