manu4panjab
hey brothers as most of u know i have emotiva xpa-5 and umc-1 i want to know when i turn oof the emotiva amp i heard thump from my speakers is it normal ,will it do any damage to my speakers :sad:
Hey Manu Bhai
You purchased sooper dooper woofer to hear it go thump! thump! thump! Now you have problem with one last thump! when it turns off?hyeah:
Many people report such a problem with their gear. How loud is it?
i always do turn on the source first then amp and amp off first then source but still there's a thump and i also turn the volume to 0 when i turn off the amp but still thump ,so it means i'm fine with thump no damage to my speakers
The noise that you hear is actually the power supply capacitors "giving up" the stored energy.Its natural and will not destroy your speakers if your amp is not turned too loud but in that case the cross overs in the speakers have their own protection circuits.
Usually home audio segment designers seldom pay attention to switch-ON/OFF thumps....
Just switch on the amp at last after switching on other equipments with volume down and switch off the amplifiers first while turning off other equipments afterwards.
Home audio amplifiers are easy going, shall not pose any problem to speakers. Things are different in pro-audio where an amplifier must have some inbuilt means to eliminate the thumps while power ON/OFF otherwise speakers have to bear the torture.
Manubhai,
keep us posted after you rectify the problem with the emotiva. Judging by your interaction with Emotiva, it appears that they are serious about their A.S.S!
