Tube buffer or cathode follower for my CD-player?
Petrus
Stip Macedonia
Hi guys!
Hello everyone.
What do you suggest for my CD-player and my amplifier with LM886, tube buffer or cathode follower?
You need to get the good tube sound.
So give suggestion what I create tube buffer or cathode follower?:rolleyes:
Thanks for the help!
Usually a Tube Buffer will contain a Cathode Follower !
A Cathode Follower is a tube stage with Unity gain ie Gain = 1.
A Pre Amplifier typically has the following 3 stages : Gain Stage + Volume Control + Buffer
A Tube Buffer typically wil not have Gain & will also not have a Volume control.
