R rone moodley New Member Joined Apr 13, 2019 Messages 1 Points 0 Location South Africa Apr 13, 2019 #1 Hi guys i just replaced the belt on my phillips turntable but it still drags and sometimes plays normally then drags again.Any suggestions
K kbhuvi Active Member Joined May 17, 2018 Messages 242 Points 43 Location New Delhi Apr 14, 2019 #2 rone moodley said: Hi guys i just replaced the belt on my phillips turntable but it still drags and sometimes plays normally then drags again.Any suggestions Click to expand... Which philips model is it. Have you lubricated the motor shaft bearing and the spindle bearing?
A analogadikt Well-Known Member Joined Feb 19, 2009 Messages 268 Points 63 Location Navi Mumbai Apr 14, 2019 #3 kbhuvi said: Which philips model is it. Have you lubricated the motor shaft bearing and the spindle bearing? Click to expand... If it is a 242 then you have to check two belts. There is a small belt inside the black box housing the motor. Check that and also lub the pully shaft. Take care not to get any oil on the belt. Regards,
K kuruvilajacob Well-Known Member Joined Jul 11, 2011 Messages 1,225 Points 113 Location Kottayam Apr 15, 2019 #4 Please ensure no oil or lubricant should be there on the belt. That will also cause dragging .
