Turntable stereo imaging issue
rajis141
hyderabad
Hi members,
I have purchased a vintage AKAI Ap307 turntable and have peculiar issues with this turntable as follows:
The stereo imaging is lacking in this turntable and the speakers appear to be playing separately.
There is a slight audible channel imbalance, the sound is more towards the left.
The quartz lock decreases the speed instead of keeping it steady at 331/3 rpm
I have done the following already:
Swapping R and L channel - Right speaker sounds louder.
Replacing the TT RCA inter connect - Done and is better than the older cables.
Turntable is leveled OK.
Tonearm balance and cartridge alignment - Perfect
FM channel and other inputs to the amp sound great with superb stereo imaging.
Azimuth - Tried to modify the tracking force and using shim to cartridge - No improvement.
Other turntables sound perfect with this stereo setup.
Tried 4 different cartridges and headshells - No improvement.
I seek Help from the knowledgeable members of this forum to identify the problem , since this is a great turntable but feel that there is some minor tweak required which I am missing out and unable to understand.
Do cross-check once more cartridge pin connections: red wire goes to right + pin, green to right - pin, white to left + pin, and blue to left - pin. When one swaps any of these, the imaging and bass sounds very weird.
Thanks. Sorry forgot to mention checked the wires of the cart leads. Its perfect.
Also checked the continuity from the tonearm pins to the RCA connector output - No issues there.
I think as per your suggestion will once again check whether the wiring connections on tonearm tally with the cartridge connections.
Yes, shine a strong light from a torch and ensure that red, green, white and blue go to the correct pins. I have made this mistake in the past and now know exactly how it sounds:D
My suspicion is on the sme connector.The spring loaded pins may not be making adequate contact or maybe covered with oxidation. The soldering of the sme pins to the tonearm wires may also have issues.
For speed issues look towards cleaning the switch and the pitch control with some contact cleaner.
Thanks. I did clean all the switches for the speed regulator. The TT spins at correct speed without the quartz lock. The moment the switch is depressed the speed decreases. Tried adjusting the VR switches but speed increases drastically. This is the set point at the moment. About 30 rpm with the quartz lock depressed. With the quartz lock released it is 331/3.
For the SME tone arm I have cleaned the contact points with Isopropyl alcohol swab. There is no problem related to connections of pins of the arm since the signal from the pin to the RCA jack is OK.
The following you may try.
1. Place a small piece of mirror on the platter and rest the Tonearm on the mirror. Check the Stylus tip is straight vertical to the plane of platter. You may use a USB microscope or a simple Magnifying lens for this.
2. Left track louder means there is a possibility of insufficient Anti skating force. Recheck once.
3. Check with a Mono record where you are getting image (middle or not)
4. If you have a test record, then connect a 47K resistor across each RCA pins and play 1kHz test track. Measure the output voltage across the resistor. If both channel are equal in magnitude and magnitude is close to the Cartridge spec then the Cartridge/TT side is perfect. If not try with different cartridge, check also the contacts/soldering in the loop..
If you have already done then
1. Check for leaky capacitors on the mother board
2. Direct drives have variable resistors (VR) for Quartz Lock adjustment. Either they are dirty or have not been adjusted properly. However, the output needs to be monitored while adjusting the VR. The ICs may also have drifted in value.
The connections may show continuity but the current generated by the cartridge is very small and it may not effectively cross the problem area resulting in suppressed sound.
I would suggest to have the some experienced tech look at it. Also consider a rewire of the tonearm to eliminate future issues.
Sorry, cant be of further help. Please do post the reasons when you get the problems sorted out.
>>>Checked. Also checked 4 different cartridges and 4 different headshell.
>>>> Checked and played around with antiskate lower or higher.
>>> Need to check
>>> Sorry no test record and cannot do electronic manipulations since i am unaware:confused:
Thanks a lot. If the tweaks don not work I will have to seek professional help.
Thanks a lot. Have seen it.
Great. What phono stage are you using? Is it the same used for all carts tested? Asking as most of the common issues have been dealt with, hence what else could be contributing to this peculiar problem?
Hi members,
why did you try to modify tracking force for changing Azimuth?
Here again I have used 3 different phono stage: 1) CNC diy 2) Schiit Mani 3) Sedco
