USB Cable Length Problem
volkankayasu
Netherlands
Hello everyone,
I have KEF LS50 speakers connected to Cambridge Azur 651A amplifier. I am listening music via my Macbook and through a USB cable connected to the amplifier. I want to use my Macbook at 7-8 meters away from the amplifier without loosing any sound quality so I need a solution for that problem. I read that after 3-5 meters usb cable length the sound quality drops. There are some people suggesting to use USB hubs but I am not sure that is going to work or not?
Any solutions, suggestions and comments?
Volkan
7 to 8 meters for a USB cable is surely not a good idea
What software do you use to play your music files ?
I think using a NAA (Network audio adapter) is the best option so you don't need to use such a long usb cable and also don't move the MacBook from where it's kept
All you need is that the NAA and macbook should be on the same network
Hello everyone,
Volkan
That is way too long to be wired. You need to think of a wireless solution. One example could you getting a Raspberry Pi along with a DAC and connecting that to your amplifier. You can then use Airplay to stream music from your Mac. You can explore various other solutions that will give you wireless connectivity over your local wifi network.
MaSh
By specification USB cable has a max length of 5m. You'll need some other solution to your problem.
If you have an HDMI interface in your PC and amplifier, try it out
You can also try chromecast, if your PC is wifi enabled and amplifier has HDMI input
大家好,
我有 KEF LS50 扬声器连接到 Cambridge Azur 651A 放大器。我通过我的 Macbook 和连接到放大器的 USB 电缆听音乐。我想在距离放大器 7-8 米的地方使用我的 Macbook,而不会损失任何音质,所以我需要解决这个问题。我读到,USB 电缆长度超过 3-5 米后,音质就会下降。有些人建议使用 USB 集线器,但我不确定这是否可行?
有什么解决方案、建议和意见吗?
沃尔坎
如果你需要长距离传输,并且保真度要求高,可以试试光纤USB,据说光纤传输最长可以达到100米,建议搜索光纤USB线,应该有适合你的。
Hello everyone,
Volkan
You can go to Amazon and search for fiber optic HDMI. It is said that the fiber optic HDMI cable can now be up to 500 meters long without signal attenuation. If you have such a need, you can buy a shorter one to meet your needs.
