USB3.0 RJ45 Gigabit Ethernet Network Card Lan Adapter
hamhifi
united states
I don't know how to use this kind of ethernet network card. What's the main function of it? Can anyone give an easy to understand answer?
If there is no ethernet port on your machine this will enable to have the LAN port with the help of connecting to the USB port. I would rather say these kind of things are more intended to get the gigabit ethernet LAN port rather than the conventional LAN ports (which I believe exist in each and every machine/pc/laptop now a days). Instead of changing the existing LAN card you can just use this to get the gigabit LAN port easily using the USB 2.0 or 3.0 ports.
This would be useful even if you need an extra network port on a machine - maybe for it to act as a bridge between two networks.
