Use Yamaha RXV 659 for HD audio
RaviB
Pune
Hi Gurus,
Is it possible to use my old RXV 659 for a DishTV HD reception and enjoy the 5.1 experience? Currently that receiver (Circa 2006) doesnot have HDMI connectevity .
Does your AVR have optical or co axial input?
If yes connect the AVR through composite for video (yellow) and do axial for surround sound
Is there any limit on length of HDMI cable from STB directly to projector / TV ? In my case length of cable required is nearly 15 mtr !
15 meter can be problematic as signal strength degrades. You need good quality hdmi cable. For such large distance you can consider hdmi to lan cable adapter.
