Using 6 ohm speaker with 8 ohm sub
k11
Chennai
Guys,
I am planning to get Jamo S426 package. Will make an order soon.
As many of you know, these are 6 ohm speakers.
I am looking for a sub for this.
Jamo Sub 210 will be better combination. This is a smaller sub.
I am also looking at bigger subs like Polk or other brands.
But most of the subs are 8 ohms.
Would there be an issue if I combine 6 ohm speakers with 8 ohm sub.
My receiver has 6ohm option at 125W per channel.
But can I set 5 speakers to 6 ohm and sub to 8ohm. Not sure if that is possible.
I got confused, when I saw some posts on matching the Jamo fronts to different set of surrounds.
Even I looked at Polk OWM3, which has 4.5" drivers instead of Jamo rear speakers having 3.5" drivers. Polks are 8ohm standard.
I might just with the package instead.
