Velodyne subwoofer repair
vkalia
Hi all -
As I start the much-delayed (10+ years... dont ask!) process of putting my system back together, I am trying to figure out if my 15-yr old Velodyne sub can be repaired and/or the driver replaced.
Anyone know if that is possible? Either via a Velo dealer or a third-party speaker builder as well.
Thanks!
Hi all -
Thanks!
I can repair your Velodine sub driver with original genuine American parts.
1. What is the woofer size ?, / model no. of the box ?,/ and sub driver part or model no., if any ??????.
2. Do you see any parts damage ?, Can you post some pics of the sub-driver.
Vivek (aka: SIDEWINDER18X)
Hi Vivek -
Let me check this and get back to you in a couple of weeks (am out of the country right now). The sub was in working condition when I moved back to India, but it's been stuck in a box for a long time in storage for a bunch of reasons, and so i expect will need some repairs.
I'll PM you when I am back and have the info.
Btw, will you also be able to convert the power supply from 120V to 220V or should I just use an external PS converter?
Thanks!
Hi Vivek -
Thanks!
Can you be more specific on everything ?. Which power supply ????.
Provide clear & specific detail before I can say something.
Anyways my speakers are also making waves in your Andaman's. A rental guy Raju is using my 15 inches. his mail id is ...... [email protected]
I am referring to the only power supply in a subwoofer that would be relevant to the 120V/220V discussion: the power input from the mains.
My Velo is set up to work with US voltage and I'd like to convert it to work with Indian mains voltage if I can, to avoid needing a separate box.
Is that power supply a conventional step down transformer based ?
If yes !, Then check whether they have used E I transformer or Toroidal transformer ???.
If it's E I ,Then it can be rewound to adapt 220v but you will loose efficiency. The output current will be half. Not advisable. Best effective solution is ..........
1. Get made a similar rating transformer with 220v primary in E I or Toroid from any good manufacturer. :)
2. If the power supply is SMPS based. Get support from Velodyne. I am sure they will provide you the correct information on the modification to the schematics to adapt it for 220v operations. :)
If both of these options are not practical for you. Then you'll have to stick on to the box. :sad:
^^ Good questions. I have no idea, as I havent opened up the innards of the subwoofer ever (back then, it was under Velodyne warranty).
I'll be in touch about repairing the driver coils anyway - perhaps then we can see if anything can be done about the input PS.
Thanks again.
